Starting problem
KUBEN GOVENDER
  • 2006 VOLKSWAGEN CADDY
  • 1.9L
  • 4 CYL
  • TURBO
  • FWD
  • MANUAL
  • 120,000 MILES
My vehicle starts okay in the morning after that takes longer to start. You have to keep acceleration pedal down and after a few swings while key kept in starting position it gets going.
Friday, March 3rd, 2017 AT 6:13 PM
SATURNTECH9
  • 30,869 POSTS
Do you get any black smoke when it starts? Sounds like you could have a bad coolant temperature sensor.
Saturday, March 4th, 2017 AT 1:53 PM
KUBEN GOVENDER
  • 5 POSTS
The caddy starts better but still have to keep accelrater pedal down and starts on second swing
Wednesday, March 8th, 2017 AT 7:02 AM
KUBEN GOVENDER
  • 5 POSTS
Tried new coolant sensor starts better but after two swings with accelerator placed flat down and swing for a little
Wednesday, March 8th, 2017 AT 7:18 AM
SATURNTECH9
  • 30,869 POSTS
Where was the sensor located you replaced?
Wednesday, March 8th, 2017 AT 12:53 PM
KUBEN GOVENDER
  • 5 POSTS
It has a two pin on one side and clips on the otherside it is near the water theremostat housing just used a screw driver to take out clip and unplug lug and then clip back on and place wire lug back 5mins
Wednesday, March 8th, 2017 AT 6:00 PM
SATURNTECH9
  • 30,869 POSTS
Is this a Diesel or Gasoline engine?I don't have any repair information on non USA model cars.
Wednesday, March 8th, 2017 AT 9:40 PM
KUBEN GOVENDER
  • 5 POSTS
Vw caddy 1.9tdi diesel motor 2006 model
Wednesday, March 8th, 2017 AT 10:14 PM
KEN L
  • MASTER CERTIFIED MECHANIC
  • 43,570 POSTS
Please connect a code reader to the car to see if there are any codes.
Here is a guide that will help you.
Please run this test and get back to us so we can continue helping you.
Best, Ken
Monday, March 13th, 2017 AT 12:04 PM
