Starter motor
SM21
  • 2002 VOLKSWAGEN POLO
  • 1.4L
  • 3 CYL
  • TURBO
  • MANUAL
  • 152,000 MILES
Hello, everyone
I am having trouble starting the car. This is the second time that happens, the same problem. I think that the starter motor is the causes this.
First time I had this issue I started the car with a bump start in order to get it to the mechanic. As soon as I arrived there the problem was fixed itself, I do not know how but it did. So I decided not to do anything.
Since then have passed four or five months, I do not know exactly how much and it happened again.
When I try to start the car in a stationary position, the starter motor makes a clicking noise.
So I am interested in knowing which is the reason why this happens and where the problem stays.
Thank you very much guys for your time.
Friday, September 28th, 2018 AT 7:56 AM
DANNY L
  • 5,648 POSTS
Hello, I am Danny.
It sounds like the solenoid on your starter motor is failing. It wears due to continuous use of cycling the starter. When you "bump" start you are bypassing the starter altogether. I have attached a tutorial showing what is involved in starter replacement. Hope this helps and thanks for using 2CarPros.
Danny-
https://www.2carpros.com/articles/how-a-starter-and-solenoid-works
Friday, September 28th, 2018 AT 2:02 PM
SM21
  • 20 POSTS
Thank you so much Danny for your help. It was very helpful and I am going try this solution.
Thank you for sharing your knowledge.
Saturday, September 29th, 2018 AT 7:30 AM
DANNY L
  • 5,648 POSTS
You are welcome!
Let me know if you have any questions about the replacement. Thanks again for using 2CarPros.
Danny-
Saturday, September 29th, 2018 AT 4:08 PM
SM21
  • 20 POSTS
Hello Danny
Actually I did not do any replacement. I took off the solenoid on my own, it looked very nice and clean, so I thought to brush the contact plates which have contact with the starter motor and all the bolts because they were a bit rusty and now everything is working pretty good.
Thank you once again, Danny for your support.
Tuesday, October 2nd, 2018 AT 1:22 AM
KEN L
  • MASTER CERTIFIED MECHANIC
  • 43,590 POSTS
Danny L is one of our best! Please use 2CarPros anytime we are here to help.
Cheers, Ken
Saturday, October 6th, 2018 AT 3:23 PM
