Sputters while in all gears
MICHLAMB1981
  • 2009 FORD FLEX
  • 3.5L
  • V6
  • 155,000 MILES
Engine light came on and car started sputtering and had diminished power. Had the engine light read and they gave us a code (don't remember the code, something with cylinder two) changed all spark plugs, cylinder two coil, took it to have an oil change and checked air filter which was fine. It has full power now but still "bounces".
Monday, January 28th, 2019 AT 2:31 PM
BMDOUBLE
  • 1,139 POSTS
Does it do this “ bouncing” during acceleration? If so you may have another coil faulty. To test this properly you need to have a scanner that will do a power balance test to verify the actual cylinder in question. That’s if this is what you are describing.
Monday, January 28th, 2019 AT 9:23 PM
MICHLAMB1981
It does not do this during acceleration. Even after replacing coil and plugs and the light came back on, the same code was read.
Tuesday, January 29th, 2019 AT 3:01 AM
BMDOUBLE
  • 1,139 POSTS
If you could get us the code we can help guide you in the right direction.
Thursday, January 31st, 2019 AT 9:38 PM
