EVAP Sensor Issues
CORZO
  • 2005 FORD FOCUS
  • 2.0L
  • 4 CYL
  • 128,000 MILES
Recently I went to the smog test and did not pass because mi EVAP monitor and catalytic monitor shows not complete. Please I need help. What can I do to pass the smog test?
Sunday, July 24th, 2016 AT 10:34 PM
HMAC300
  • 48,600 POSTS
What is the code that is given auto parts checks for free. Get back with us on this.
Monday, July 25th, 2016 AT 7:09 AM
CORZO
  • 11 POSTS
The car did not shows any code that is the problem also.
Monday, July 25th, 2016 AT 3:31 PM
HMAC300
  • 48,600 POSTS
Try another scanner some wont work others will, check fuel pressure as well with a gauge auto parts rent it.
Monday, July 25th, 2016 AT 4:23 PM
CORZO
  • 11 POSTS
That is for the evap monitor, can you give me how can solve the problem with the catalytic monitor? Thanks a lot.
Tuesday, July 26th, 2016 AT 3:17 PM
HMAC300
  • 48,600 POSTS
There isn't a code to give for catalytic monitor the only thing I can think of is an O2 sensor may not be heating up right. Or it is a can bus problem that can only be seen by a professional scanner not auto parts.
Tuesday, July 26th, 2016 AT 4:43 PM
CORZO
  • 11 POSTS
Thanks men you are the best, appreciate all of your advice.
Tuesday, July 26th, 2016 AT 6:12 PM
SATURNTECH9
  • 30,869 POSTS
Just to add to this one before you went to the smog test did you clear any codes in the computer battery die or was it replaced?
Wednesday, July 27th, 2016 AT 12:36 PM
CORZO
  • 11 POSTS
Now the check engine light is on due to P0420 code catalytic converter.
Wednesday, July 27th, 2016 AT 3:32 PM
SATURNTECH9
  • 30,869 POSTS
Sounds like the codes were cleared at some point that's why the monitors wernt ready. When the battery dies or is replaced or codes are cleared. The monitors get cleared and have to be reset by driving/operating under certain conditions. Sounds like you have a bad cat from the code you have. As long as there are no exhaust leaks then more then likely you have a bad cat.
Wednesday, July 27th, 2016 AT 6:08 PM
CORZO
  • 11 POSTS
Yea I notice that I already bought a new one thanks guys a lot for the advice, am just waiting to install it
Wednesday, July 27th, 2016 AT 7:06 PM
SATURNTECH9
  • 30,869 POSTS
After you get it installed you will have to clear codes and drive it for a few days and see how the monitors look. It can take a while for them to set. Also your welcome were here to help.
Wednesday, July 27th, 2016 AT 8:46 PM
CORZO
  • 11 POSTS
Thanks guys
Wednesday, July 27th, 2016 AT 10:27 PM
  • 31,937 POSTS
How did you get on? Any up date yet?
Tuesday, August 2nd, 2016 AT 2:36 PM
CORZO
  • 11 POSTS
I already install a new catalytic now I have to drive a little I thought
Tuesday, August 2nd, 2016 AT 7:38 PM
SATURNTECH9
  • 30,869 POSTS
Yes clear the codes and drive it a while to set the monitors.
Tuesday, August 2nd, 2016 AT 7:40 PM
CORZO
  • 11 POSTS
Thanks pals everything is going awesome, I appreciate all the good advises from you guys
Tuesday, August 2nd, 2016 AT 11:16 PM
SATURNTECH9
  • 30,869 POSTS
Your welcome were here to help please tell all your friends about us.
Wednesday, August 3rd, 2016 AT 12:12 AM
CORZO
  • 11 POSTS
Of course I will
Wednesday, August 3rd, 2016 AT 2:20 PM
SATURNTECH9
  • 30,869 POSTS
Thanks we really appreciate it we want to help as many people as we can.
Wednesday, August 3rd, 2016 AT 7:42 PM
