2001 Saturn SL2 Tires leaking
LCLICKER
  • 2001 SATURN SL2
Tires and Wheels problem
2001 Saturn SL2 90000 miles
My husband took his car in to get new cars in September of 2009. Since then all 4 tires have been leaking slowly. He has to fill the tires once every week or two. I had the tires installed at Firestone and when I called them to state the problem I was told that since the tires were put on around winter and the wheels are aluminun salt has gotten into the beading and caused it to basically corrode so the tire is not sitting properly. This is what is causing the leak. I am not buying it. This is the 3rd set of tires we have had on this car and we have never had this problem. I talked with my father and he is guessing that they did not properly clean the rim before installing the new tires. They want to charge me 25 a tire to clean and reinstall. Any input or adive would be appreciated.
Monday, June 21st, 2010 AT 6:52 AM
  • 31,937 POSTS
Hi there,
I would be reminding them that they should have cleaned the beads in the first place as this is a fairly standard practice, but in the end if they wont do it, is it worth the agro. See what they say.
Mark (mhpautos)
Monday, June 21st, 2010 AT 7:11 AM
