2000 Saturn SL2 IGNITION AND STEERING WHEEL
NUBIANJANINE41
  • 2000 SATURN SL2
  • V8
  • 4WD
  • 145,000 MILES
WHEN I PUT IN KEY TO START KEY WILL NOT TURN AND GEARS WILL NOT GET OUT OF PARK, WHAT IS THE PROBLEM
Tuesday, June 30th, 2009 AT 10:57 AM
SATURNTECH9
  • 30,869 POSTS
So the key won't turn at all?Have you tried turning the steering wheel while turning the key at the same time?Also look at the key does it looked badly worn down?If so do you have another key that isn't so worn down to try?Also have you tried wiggling the key up and down while trying to turn it?
Wednesday, June 8th, 2011 AT 9:33 PM
