1998 Saturn SL2 cruise control
PETTA24
  • 1998 SATURN SL2
Engine Performance problem
1998 Saturn SL2 4 cyl Front Wheel Drive Automatic
recently my car stalled for the first time while I was inline at a drive through. It took three cranks but eventually it started thank god, now the vehicle seems to be driving like it is cruise control. I take my foot of the gas and and continues to accelarate and takes a long time to deaccelerate. Also when I apply the break it revs up to 2 on the rpm meter, just seems like the engine is getting gas when im not applying it, also I might me paranoid but it looks like there is gas leaking from under my car I noticed in the parking lot this mornig, any suggestions, like maybe fuel pump or 02 sensor or something
Thursday, January 22nd, 2009 AT 4:37 PM
KEVIN12881
  • 336 POSTS
Sounds like a throttle control sensor. You can put some card board under the car to better see what it leaks overnight. Donate for a pro to help, a few bucks will do. You RPM problem could be a number of thins, but I doubt it has anything to do with the cruise control. You can take the cruise control fuse out if it makes you feel better
Thursday, January 22nd, 2009 AT 4:52 PM
