1995 Saturn SL2 rough idle
MATT KIRSCHBAUM
  • 1995 SATURN SL2
  • 4 CYL
  • 93,000 MILES
Our car has a little rough idle and when put into gear the cars idle goes up rpms and if you dont keep your foot on the brake it will slam gears
Sunday, July 25th, 2010 AT 1:11 PM
SATURNTECH9
  • 30,869 POSTS
So how does the car run down the road does it miss fire while your driving?Or does it only run rough when at idle?Also what do you mean if you don't hold your foot on the brake while putting it in gear it slam's into gear?You always have your foot on the brake when you put it in gear.
Sunday, July 25th, 2010 AT 1:23 PM
MATT KIRSCHBAUM
It takes longer to shifting into gears and its just a rough idle no misfires. Perhaps a crank sensor or throttle sensor
Tuesday, July 27th, 2010 AT 8:16 PM
SATURNTECH9
  • 30,869 POSTS
If you don't have any miss fire's and the idle feel's rough in park I would look at the upper motor mount for being torn or collasped if it get's rough when you put it in drive then I would look at the lower transmission mount for being torn or collasped. Real common for both mount's so I would check both of them. Also do you have code's?
Wednesday, July 28th, 2010 AT 12:42 PM
