1993 Saturn SL2 speedometer-odometer
BIOMEDBOB
  • 1993 SATURN SL2
  • 4 CYL
  • FWD
  • MANUAL
  • 250,000 MILES
The speedometer works fine, but the odometer and tachometer do not.
fuse? Wiring? Sensor?
Monday, January 18th, 2010 AT 2:11 PM
SATURNTECH9
  • 30,869 POSTS
Well on the odometer the little plastic gear is probably broken drives it very common. My sisters 93 her odometer went out put a used one in it then two weeks later that one went out too. They sell the gear but u have to take the whole cluster to replace it. Unless ur good at fixing things I wouldnt try it. As far as ur tach have u tried smacking ur dash while its running to see if the tach moves?If that doesnt work u would have to trace the wires to ur tach to make sure there good and if they were then would have a bad tach but u cant just get the tach ur car comes as a whole cluster assembley. Let me know what u find.
Tuesday, January 19th, 2010 AT 12:56 PM
