1999 Saturn SL1 transmission cost
DLMNF4
  • 1999 SATURN SL1
  • 4 CYL
  • FWD
  • 172,900 MILES
How much would it cost to either rebuild the transmission, or put in a new transmission, on a 99 Saturn SL1?
Thursday, August 19th, 2010 AT 2:54 PM
SATURNTECH9
  • 30,869 POSTS
First of all thank you so much for your donation.I have only had to rebuild a handful of transmission's on the saturn S model. There really good transmission's so let's start with what problem your having with your transmission. Then I can tell you the best way to repair it.
Thursday, August 19th, 2010 AT 3:15 PM
DLMNF4
It shifts roughly between 1st and second gear, and it slips in and out of third gear
Thursday, August 19th, 2010 AT 3:20 PM
SATURNTECH9
  • 30,869 POSTS
So you have a hard shift between first and second?It also slip's in and out of third?When you say it slip's in and out of third doe's it shift to a lower gear?Or does it just freewheel?Also do you have any code's?If you don't know could you please go to a auto part's store and see what code's you have and let me know what the number's are.
Thursday, August 19th, 2010 AT 3:28 PM
