1996 Saturn SL1 1996 Saturn SL1 horn
STAUSHA
  • 1996 SATURN SL1
  • 4 CYL
  • 176,000 MILES
Horn doesn't work tried changing fuses and still doesnt work. What could it be?
Friday, October 8th, 2010 AT 4:56 PM
SATURNTECH9
  • 30,869 POSTS
You could have bad wiring horn switch or horn. Do you have a test light?
Friday, October 8th, 2010 AT 5:24 PM
STAUSHA
  • 6 POSTS
Yes I tested the fuses and they work ( if thats what your tlkn bout).
Friday, October 8th, 2010 AT 5:27 PM
SATURNTECH9
  • 30,869 POSTS
No I was thinking about you removing the driver side head light assembly and seeing if the orange wire terminal A to the horn wire has power the black wire terminal C has a constant ground and the black wire terminal B has a ground when pressing the horn button.
Friday, October 8th, 2010 AT 5:43 PM
