1993 Saturn SL1 dash lights
APRLLMAY
  • 1993 SATURN SL1
1993 Saturn SL1 4 cyl Two Wheel Drive Automatic
where do I replace the fuse to the dash lights and also what size fuse do I need
Friday, December 11th, 2009 AT 11:31 AM
SATURNTECH9
  • 30,869 POSTS
There's a dimmer fuse in the fuse box inside the car behind the passenger foward kick panel I belive it's 5 amp it's labeled dim. Also in ur underhood fuse box check ur parking light fuse also I belive it's 10 amp there both the mini fuse type. Let ne know how it goes. Also check ur dimmer switch make sure it's not turned all the way down.
Louie
Friday, December 11th, 2009 AT 1:23 PM
