The passenger front brake caliper is not compressing?
PAGE0210
  • 1999 TOYOTA CAMRY
  • 2.2L
  • 4 CYL
  • 220,000 MILES
I tried bleeding the brakes and got absolutely no fluid. So far, I have replaced the caliper, the brake hose, searched for line brakes and took out the master cylinder, bench blead it and nothing. There are bubbles coming from the center of the cylinder so there is a leak somewhere, but no fluid is ever lost.
Friday, April 26th, 2024 AT 2:05 AM
KEN L
  • MASTER CERTIFIED MECHANIC
  • 43,052 POSTS
So, the new and old brake caliper will not compress, correct? Will the new caliper compress without the brake line attached? Here is the correct way to bleed the brake master in case you need it.
https://youtu.be/WDxvEQrMkBg?si=7BX-4RJ1J--q2b-0
Please upload pictures or videos in your response to the problem so we can see what's going on.
Friday, April 26th, 2024 AT 10:37 AM
