HOME
ASK A QUESTION
REPAIR GUIDES
BECOME A MEMBER
LOG IN
Login with Facebook
OR
Remember me
NOT A MEMBER?
FORGOT PASSWORD?
CONTACT US
PRIVACY POLICY
TERMS AND CONDITIONS
Home
Saturn
L300
Engine
Intake Manifold
Replace/Remove
Replacement manifold hose parts?
HOLMESDANIEL508
MEMBER
2005 SATURN L300
3.0L
V6
2WD
AUTOMATIC
186,000 MILES
I can't find any intake manifold hose replacement parts #90501507, #90571136.
Friday, August 18th, 2023 AT 1:40 PM
KEN L
MASTER CERTIFIED MECHANIC
Those parts are obsolete, you will need to fabricate a piece that will work or try eBay.
SPONSORED LINKS
Saturday, August 19th, 2023 AT 10:36 AM
Please
login
or
register
to post a reply.
Related Intake Manifold Replace/Remove Content
Oil Change
Was Changing Oil On 2005 L300 Saturn Sedan V6 Front Wheel Drive Automatic. The Oil Cap Was On Too Tight And In Process Of Unscrewing It The...
Asked by
Mjmc
2005
SATURN L300
VIDEO
Instructional repair video
GUIDE
Intake Manifold Replacement
When an intake gasket or intake manifold fails it can create a vacuum or coolant leak which will cause the engine to run poorly or overheat. This can happen over time, if...
Thick Mixture Of Oil Only In Cooling System
Driving Noticed Steam, Was Not Overheating. Stopped Seem Bottom Driver Side Radiator Hose Sprung A Leak. It Was Not But About Two Miles...
Asked by
Timothy Foley
2002
SATURN L300
2001 Saturn L300 Takes Forever To Start
Mechanic Isn't Sure, Computer Says It Is Misfiring. Sometimes It Will Start 2nd Or 3rd Try Sometimes 30 Minutes Trying. The Part(throttle...
Asked by
AMEMUS
2001
SATURN L300
2003 Saturn L300 L300 Engine
Saturn L300 V6 100000 Miles. Driving Along And Suddenly Lost A Bunch Of Power. 2 Min Later Lost All Power And The Engine Would Hardly Idle....
Asked by
DIGGSBEE
1 ANSWER
2003
SATURN L300
SPONSORED LINKS
Cooling System Pressure Test For Leaks
Throttle Bore & IAC Service Toyota Tacoma
Online car repair manuals
