Recommend idling RPM
MO-SAN
  • 2007 CHEVROLET TAHOE
  • 5.3L
  • V8
  • 4WD
  • 72,000 MILES
Idling rpm on my SUV is about 800 rpm's which I thought is high. What is the recommended idling rpm and can it be adjusted by using a computerized scanner to the desired setting? Thanks
Sunday, March 25th, 2018 AT 4:25 AM
WRENCHTECH
  • 20,758 POSTS
The idle rpm is entirely controlled by the computer and is not adjustable at all. If you are not getting a check engine light, then the system is likely working as designed. The rpm's will vary with temperature and conditions.
Sunday, March 25th, 2018 AT 8:21 AM
MO-SAN
  • 31 POSTS
Thanks for the answer. Is a great help. I can now move forward with my trouble shooting.
Sunday, March 25th, 2018 AT 10:12 PM
STEVE W.
  • 13,121 POSTS
If you are only using the dash tachometer the rpm is probably fine. They can be a bit off. Toss a scan tool on it and look at the live data and see what it shows. Does it have any other issues? A tiny vacuum leak could cause the idle to rise.
Normal idle on the 5.3 is around 600 rpm when warmed up. Starting cold rpm will run up to 1,000 then lower as it warms up. You might want to look at the vacuum lines and gaskets to be sure there is not a leak.
Tuesday, March 27th, 2018 AT 9:50 AM
WRENCHTECH
  • 20,758 POSTS
A vacuum leak will tend to raise the idle but it will also eventually also set a lean code and put the check engine light on. So again if you have no check engine light, chances are it is normal.
Tuesday, March 27th, 2018 AT 10:10 AM
STEVE W.
  • 13,121 POSTS
That is why I said it could be a leak. The other issue is what is he trouble shooting for? Very well could be related.
Tuesday, March 27th, 2018 AT 10:31 AM
MO-SAN
  • 31 POSTS
Thanks Steve, the trouble shooting which I have already done by checking related vacuum lines for cracks on the hoses all seems to be fine and I do not have a check engine light either. I was observing a low mileage on my truck for awhile now since I replaced my factory exhaust system to flow master series of getting this moderate sound instead of hearing the sounds of the engine. And this leads to my next question, should I be getting a bit higher mileage as the ad said or less mileage compared to the factory exhaust system? Because my mileage has drop after the replacement. Any thoughts on this issue question will highly be appreciated to put my mind at peace. Again thanks.
Tuesday, March 27th, 2018 AT 3:49 PM
STEVE W.
  • 13,121 POSTS
Well if you are like most people who put on a non-factory set of mufflers, you probably like to hear them a bit more. So you step on the gas a bit more often and maybe rev the engine a bit more than you used to. That alone can alter the fuel mileage. Now if you are driving it exactly the same, using the same fuel and everything else is the same, you should get right about the same mileage. I have seen full cat back systems get better mileage than stock and some get worse. 99% of that is due to the driver.
With the mileage you have you might think about cleaning the throttle body, and doing a top cylinder cleaning. Most of the newer engines seem to build more carbon due to the emissions systems and the throttle bores and valves bear the brunt of it. Lot's of videos on those processes out there, watch a few and see if they might help.
Tuesday, March 27th, 2018 AT 4:24 PM
MO-SAN
  • 31 POSTS
Okay to the very well thoughts. I will start from my air filter, MAF and make my way to the throttle body and see if it makes a difference. Yes, you are 100% right, I do step on the gas to hear them a bit. I will try after any cleaning to drive normal to see the difference it makes before I start criticizing the product. Thanks for your time and will update my results later.
Tuesday, March 27th, 2018 AT 7:32 PM
