The vehicle started to make some rattling noise from the engine and the engine light came on?
STRONG POWER BRICK MACHINES
MEMBER
2015 FORD AA
1.5L
4 CYL
MANUAL
120,000 MILES
I noticed that the vehicle started to make some rattling noise from the engine and the engine light came on. I changed the spark plugs and it got better but it was still shaking. It is not performing on optimum power as it loses power when driving. The sound has changed as well when idling.
SPONSORED LINKS
Tuesday, April 23rd, 2024 AT 11:20 AM
MECHANIC
Based on your description, the first thing that comes to mind is an internally loose catalytic converter. Try this. Take a rubber mallet and tap on the exhaust system to see if you can reproduce the noise. Take a look through these links as well. The first one describes symptoms related to a failing converter and the second shows how to check.
