Power steering pump shaft and belt tension-er
ABO6DAT
  • 2004 FORD TAURUS
  • 3.0L
  • V6
  • FWD
  • 117,000 MILES
Hello, I sure do appreciate you all being here. I have a couple of more questions that I would like to ask you all. Can you all tell me if the rod shaft that my power steering pulley is mounted on is the shaft supposed to have a little play in it? If not what do I need to do to it? I noticed that my belt tension-er has three marks on it with a hole in behind the three marks. Can you tell me what the three marks are for?
Sunday, June 25th, 2017 AT 10:18 AM
KEN L
  • MASTER CERTIFIED MECHANIC
  • 42,940 POSTS
Yes you should have some play about 1/8 inch in the pump shaft. The three marks on the tensioner mean minimum/maximum and ideal tension on the belt.
Please use 2CarPros anytime, we are here to help. Tell a friend please.
Cheers, Ken
Tuesday, June 27th, 2017 AT 1:49 PM
ABO6DAT
  • 7 POSTS
Can u all tell me if I can set the tensioner2take just a little bit of slack out the belt&walk me thru it slow on how2do it?
Tuesday, June 27th, 2017 AT 4:38 PM
KEN L
  • 42,940 POSTS
The best way to take slack out of the belt is get a smaller belt or replace the tensioner.
Tuesday, June 27th, 2017 AT 7:20 PM
