Check engine light and code P0496
JAMES KINTON
  • 2010 GMC ACADIA
  • 3.6L
  • 6 CYL
  • FWD
  • 140,000 MILES
Hi, my engine light came on. I took it to my local auto part store the scanned it and p0496 code come up twice. I replaced fuel rail sensor an the purge valve. My engine light is still on. What else can I do? Trying to avoid taking to a mechanic. Please help
Saturday, October 15th, 2016 AT 6:43 PM
SATURNTECH9
  • 30,869 POSTS
Where was the purge valve located you replaced?
Saturday, October 15th, 2016 AT 8:09 PM
JAMES KINTON
  • 10 POSTS
In the front right side of engine.
Sunday, October 16th, 2016 AT 7:19 AM
JAMES KINTON
  • 10 POSTS
Diverside.
Sunday, October 16th, 2016 AT 7:20 AM
JAMES KINTON
  • 10 POSTS
Sorry to post so many. I know the purge valve was bad because it would not close. My engine light did go off for a day and the next morning came back on.
Sunday, October 16th, 2016 AT 7:23 AM
SATURNTECH9
  • 30,869 POSTS
It is common for the canister purge solenoid valves to stick open like that. What I would like to see is what the fuel pressure tank sensor is reading with the engine off gas cap off and the key in the run position. That would take a advanced scan tool with live data to read that. I have seen those fuel tank pressure sensors get stuck so it tells the computer there is vacuum to tank when there really is not.
Sunday, October 16th, 2016 AT 8:36 AM
