P0300 why would a car only have this code?
BHAMDOC1973
  • 2013 CHEVROLET EQUINOX
  • 4 CYL
  • 102,000 MILES
Very minor idle stumble but overall smooth. Why would a car only have this code?
Sunday, August 21st, 2022 AT 2:01 PM
  • 108,554 POSTS
A P0300 indicates a random misfire. This can be caused by a few things. Since you indicated it runs good other than a minor stumble at idle, my first suspect would be an engine vacuum leak or the need for a tune-up.
Has the vehicle been tuned up with new spark plugs recently? It should be done by 100K. If it has, then I need you to check for engine vacuum leaks. Here is a link that explains how to do it:
Sunday, August 21st, 2022 AT 8:46 PM
