HOME
ASK A QUESTION
REPAIR GUIDES
BECOME A MEMBER
LOG IN
Login with Facebook
OR
Remember me
NOT A MEMBER?
FORGOT PASSWORD?
CONTACT US
PRIVACY POLICY
TERMS AND CONDITIONS
Home
Ford
Truck
Engine
Symptoms
Overheat
Overheating
RANDY WHITE2
MEMBER
2000 FORD TRUCK
V12
2WD
75,000 MILES
Clutch fan won't engage until engine temperature is red line. Clutch was replaced as old one did same thing.
Wednesday, May 29th, 2019 AT 2:03 PM
KEN L
MASTER CERTIFIED MECHANIC
When you replaced the fan clutch did you use OEM? Also I have seen a blown head gasket cause this problem lets run this test to confirm:
SPONSORED LINKS
Thursday, May 30th, 2019 AT 2:10 PM
Please
login
or
register
to post a reply.
Related Engine Overheat Content
1997 Ford Truck Overheating
Have A F-150 That When Cold, Comes Up To Running Temp For About 1-2 Miles Then Temp Gauge Drops To Cold, Lose Heat For About 1 Mile Then...
Asked by
daniel470
1997
FORD TRUCK
VIDEO
Is Your Engine Cool Enough to Check?
Instructional repair video
GUIDE
Overheating Symptoms
An overheating engine is never a good thing to have happen. If the problem is caught quickly you can save the headache of a major engine repair. Knowing the information from...
2000 Ford Truck My Truck Do Not Want To Start
My Truck It Is A 7.3 Power Stroke Diesel It Does Crank But Do Not Start Some Body Have Any Idea What's Going On?
Asked by
kotato
1 ANSWER
2000
FORD TRUCK
2000 Ford Truck Engine Started To Missfire
Recently My Engine (5.4l) Started To Miss On #4 Cyclinder And Also The Obd 2 Said There Was A Lean Fuel Mixture On Bank #1. I Just Got...
Asked by
rchanson
1 ANSWER
2000
FORD TRUCK
2002 Ford Truck Turns Over But Will Not Start
Parked 2002 F-150 Lariat In Drive After Routine Errands. Returned A Few Days Later To Use, Truck Unlocks Normally With Keyless, Key And...
Asked by
Elbee767
2002
FORD TRUCK
Coolant In Oil
I Have A 1996 Cummins C 8.3l - 210 Hp. Last Week, Doing My Pre-check, I Noticed My Coolant Level Was Almost 1 Gallon Low (never Low). I...
Asked by
Garbage Man
1996
FORD TRUCK
VIEW MORE
SPONSORED LINKS
Coolant Leak Repair
Online car repair manuals
