Overheating
SUMMER529
  • 1994 CHEVROLET S-10
  • 4.3L
  • 6 CYL
  • 4WD
  • 150 MILES
I replaced my radiator and my water pump and after I did that the truck is overheating and blowing out cold air
Sunday, January 27th, 2019 AT 4:57 PM
  • 52,797 POSTS
Good evening
It sounds like you have air in the system.
https://www.2carpros.com/articles/car-heater-not-working
What have you tried to bleed the system?
https://www.2carpros.com/articles/engine-cooling-system
Why did you replace the radiator and water pump?
Sunday, January 27th, 2019 AT 5:58 PM
SUMMER529
  • 24 POSTS
My fiance replace the radiator and water pump because the coolant was leaking from the bottom of the truck somewhere and we couldn't figure out where it was coming from and it was not overheating and so we deciphered where the leak was coming from which was the water pump and now that those have been changed and he put water into where the coolant goes and turn it on and drove it for a minute and it started overheating
Sunday, January 27th, 2019 AT 6:04 PM
  • 52,797 POSTS
OK, it sounds like the system needs to be bled.
Have him let it idle until the thermostat opens. Have him add coolant as needed. Once the thermostat opens, run the engine at 1200 rpm and turn on the heater. Have someone watching the coolant level and add as needed. Once you get heat, the air is out of the system and you can install the cap.
Sunday, January 27th, 2019 AT 6:09 PM
SUMMER529
  • 24 POSTS
Thank you!
Sunday, January 27th, 2019 AT 6:13 PM
SUMMER529
  • 24 POSTS
He says it overheats before he even gets the heater turned on and it only takes a couple minutes before the heater to turn on and he wants to know does he let the truck stay running
Sunday, January 27th, 2019 AT 6:16 PM
  • 52,797 POSTS
When it starts to overheat, the coolant level should drop and he can add coolant. If not, then the thermostat may not be opening.
Did he replace the thermostat?
Sunday, January 27th, 2019 AT 6:19 PM
SUMMER529
  • 24 POSTS
No he has not
Sunday, January 27th, 2019 AT 6:28 PM
  • 52,797 POSTS
Then he needs to start there.
Sunday, January 27th, 2019 AT 6:43 PM
SUMMER529
  • 24 POSTS
Thank you
Sunday, January 27th, 2019 AT 6:47 PM
  • 52,797 POSTS
Your welcome
Always glad to help
Sunday, January 27th, 2019 AT 6:50 PM
SUMMER529
  • 24 POSTS
May I ask you some questions about my about my Lexus LS400
Sunday, January 27th, 2019 AT 7:29 PM
HARRY P
  • 2,292 POSTS
I tend to agree with Roy. You need a new thermostat. Costs about $10 at the local parts shop, takes all of 2 minutes to replace. A bad thermostat would cause the pressure to build in the cooling system. A weakened part, such as an old water pump or radiator, may crack and start to leak before the pressure builds enough to go out of the radiator cap and into the overflow reservoir.
Go ahead and replace that thermostat. While you're at the parts store, borrow the cooling system pressure test gauge and use it to check for other leaks. I suggest this because at 150k miles on this truck, it's pretty common for the lower intake manifold gasket to have hardened and start leaking coolant into the intake, which lets it get into the combustion chambers and potentially cause other issues.
How to pressure test a cooling system: https://www.2carpros.com/articles/radiator-pressure-test
Good luck on that. As for the Lexus, please start a new thread for it here: https://www.2carpros.com/questions/new
Thanks for using 2carpros
Sunday, January 27th, 2019 AT 8:52 PM
SUMMER529
  • 24 POSTS
Ok so backing up a few responses, when I told him what you said before you decided on the thermostat needed changed, he said he added coolant and before he even turned the truck on it was leaking. Does he still start the truck and let the truck run for a min? And should it still be leaking?
Sunday, January 27th, 2019 AT 9:26 PM
  • 52,797 POSTS
No, you need to find the leak with a pressure tester. That needs to be addressed along with replacing the thermostat.
As for the Lexus, you need to start a new question. Site rules only allow one vehicle per question.
Www.2carpros. Com/question
Monday, January 28th, 2019 AT 2:26 AM
HARRY P
  • 2,292 POSTS
Tell him to make sure that the drain plug on the bottom of the radiator tank nearest the passenger side is closed completely. Turn it clockwise, like you're tightening a screw.
Monday, January 28th, 2019 AT 3:52 AM
