HOME
ASK A QUESTION
REPAIR GUIDES
BECOME A MEMBER
LOG IN
Login with Facebook
OR
Remember me
NOT A MEMBER?
FORGOT PASSWORD?
CONTACT US
PRIVACY POLICY
TERMS AND CONDITIONS
Home
Oldsmobile
Cutlass
Steering
Tie Rod End
Replace/Remove
1997 Oldsmobile Cutlass replace inner tie rod
TAWATER
MEMBER
1997 OLDSMOBILE CUTLASS
6 CYL
2WD
AUTOMATIC
120,000 MILES
What is the procedure to replace the inner tie rod
Monday, June 16th, 2008 AT 5:54 PM
BLACKOP555
MECHANIC
Remove tire, mark and remove out tie rod end.
remove bolt and use a pickle fork to separate the tie rod from the drank link,
installation is reverse of opposite.
for pictures and specifications go here
https://www.2carpros.com/kpages/auto_repair_manuals.htm
SPONSORED LINKS
Monday, June 16th, 2008 AT 7:29 PM
Please
login
or
register
to post a reply.
Related Tie Rod End Replace/Remove Content
1994 Oldsmobile Cutlass Tie Rod Replacement
Steering Problem 1994 Oldsmobile Cutlass 6 Cyl Front Wheel Drive Automatic 204k Miles We're Replacing The Inner And Outer Tie Rods....
Asked by
jujubee
1 ANSWER
1994
OLDSMOBILE CUTLASS
GUIDE
Tie Rod End Replacement
EV's and gas power cars are equipped which tie rod ends which is needed to connect the rack and pinion or steering box to the spindle and front wheels that control the...
1995 Oldsmobile Cutlass Tie Rod That Won't Budge
I'm Replacing The Outer Tie Rods On Both Ends Of My Olds, And No Matter What I Try, I Can't Get The To Let Go Of The Steering Knuckle. I...
Asked by
ronseipel
1995
OLDSMOBILE CUTLASS
1987 Oldsmobile Cutlass Steering Wheel Problem
The Steering Wheel On My 87 Olds Cutlass Ciera Moves Up And Down And Side To Side With A Lot Of Excessive Play Without Using The Vertical...
Asked by
HOLLA8585
1 ANSWER
1987
OLDSMOBILE CUTLASS
1987 Oldsmobile Cutlass Tie Rods
Steering Problem 1987 Oldsmobile Cutlass 4 Cyl Front Wheel Drive Automatic I Just Bought A Cutlass Ceiara Off My Girlfriends Mom....
Asked by
Venom_101
1987
OLDSMOBILE CUTLASS
Steering Column Tranny Gearshifter
1996 Olds Cutlass Ciera. I Can Start Car But Cannot Shift Tranny In Gear. Sometimes If I Turn Steering Wheel Back And Forthit Will Free...
Asked by
sillyc2
1996
OLDSMOBILE CUTLASS
VIEW MORE
SPONSORED LINKS
Steering Wheel Shaking
Steering Pump Replacement Mercedes Benz
How to Replace a Power Steering Pump
Online car repair manuals
