1988 Oldsmobile Cutlass Changing a tire
LOSDIGGITY
  • 1988 OLDSMOBILE CUTLASS
1988 Oldsmobile Cutlass Two Wheel Drive
How do you change a tire for a 1988 Oldmobile Cutlass Sierra? The tire does want to come off?
Friday, December 5th, 2008 AT 12:30 PM
  • 108,524 POSTS
Hi:
If you have the lug nuts removed and the tire is still tight, you will need to hammar it off from the rear of the tire. Corrosion sometimes causes the wheel to stick. If you can, use a dead blow hammar (rubber coated) and is less likely to damage the wheel.
Let me know if this helps.
Thursday, December 11th, 2008 AT 2:54 PM
