1999 Oldsmobile Aurora BOLTS BROKE WITH LUG NUTS ATTACHED
BIGMOMMAJ
MEMBER
1999 OLDSMOBILE AURORA
V8
FWD
AUTOMATIC
146,578 MILES
WE HEARD THE TIRE MAKING A NOISE SO WE STOPPED TO CHECK IT AN WHEN WE REMOVED THE PLASTIC PEICE WE DISCOVER TWO OF THE BOLTS THAT HOLD THE TIRE IN PLACE HAD BROK OFF & WERE JUST LYING LOSE IN THERE. CAN WE REPLACE JUST THE BOLTS OR WILL THE WHOLE PEICE NEED TOBE REPLACED?
SPONSORED LINKS
Tuesday, February 10th, 2009 AT 3:33 PM
MECHANIC
Hi:
If the stud has broken, replace both. You will need to remove the wheel, caliper and rotor to remove the broken stud and replace it.
