1997 Oldsmobile Aurora steering wheel loose
BWASHING1
  • 1997 OLDSMOBILE AURORA
  • V8
  • 300,000 MILES
My steering wheel is loose and it looks like it has to pins or studs that are suppose to hold it in place. What do I need to fix it. It moves from side to side up and down.
Tuesday, April 21st, 2009 AT 10:39 AM
  • 108,517 POSTS
It could be the tilt wheel component that is loose. You need to remove the steering wheel and part of the column to access it unless the entire column from top to bottom is loose.
Tuesday, September 15th, 2009 AT 12:12 PM
