How to remove the oil sensor shield?
SUSAN SCHAEFER
  • 2010 CHEVROLET TAHOE
  • 4WD
  • 150,000 MILES
I am installing a new oil sensor. There is a plastic shield making access difficult. I want to remove this piece of plastic as it appears useless. Any reason I should not remove the shield?
Thursday, November 16th, 2023 AT 11:43 AM
  • 108,401 POSTS
Hi Susan,
I'm not sure which shield you are referring to or the engine size to see if I can find it in a manual. What size engine does the vehicle have?
Also, is it possible for you to take a pic of the item and upload it for me to see? If it is there, chances are it is important or at least needed. LOL
One other thought, if this has the 5.3L engine, I believe the intake needs to be removed to access the oil pressure sensor.
Thursday, November 16th, 2023 AT 9:20 PM
