HOME
ASK A QUESTION
REPAIR GUIDES
BECOME A MEMBER
LOG IN
Login with Facebook
OR
Remember me
NOT A MEMBER?
FORGOT PASSWORD?
CONTACT US
PRIVACY POLICY
TERMS AND CONDITIONS
Home
Chevrolet
Tahoe
Engine
Oil Pressure Sensor
SPONSORED LINKS
Oil pressure switch test
THUNDER123
MEMBER
1999 CHEVROLET TAHOE
5.7L
V8
2WD
AUTOMATIC
202,000 MILES
When I unplug the fuel pump relay the engine shuts off. Does that mean the oil pressure switch is bad?
Friday, June 7th, 2019 AT 10:53 AM
SCGRANTURISMO
MECHANIC
No. It simply means that you have created an open in your fuel pump circuit and that is the reason your vehicle shuts off.
Thanks,
Alex
2CarPros
SPONSORED LINKS
Friday, June 7th, 2019 AT 3:16 PM
THUNDER123
MEMBER
Okay, thanks.
Friday, June 7th, 2019 AT 3:55 PM
Please
login
or
register
to post a reply.
Related Oil Pressure Sensor Content
2003 Chevy Tahoe Oil Sensor & Fuel Gague
Having A Problem With Both The Oil Pressure And The Fuel Level Gauge. Both Seem To Work Some Of The Time. The Oil Pressure Could Probably...
Asked by
BernieJ
2003
CHEVROLET TAHOE
1999 Chevy Tahoe Lean's In Bank 1&2/vacuum Lines
I Tested My Truck With The Computer And The Computer Read's It's A Lean In Bank 1&2. What Am I To Do
Asked by
fuquan ali shabazz
1 ANSWER
1999
CHEVROLET TAHOE
After Tune Up Engine Running Terrible
I Have 99 Tahoe Just Had It Tune Up Now It Will Only Do About 20 Mph They Seam To Think It Has Jump Time Can You Help Me With This.
Asked by
sheila jackson
1 ANSWER
1999
CHEVROLET TAHOE
Engine Cranks But It Can Take Up To 5 Seconds To Start...
I Have Done A Complete Tune Up Including Spark Plugs, Wires, Distributor Cap, Rotor Button, & Fuel Filter. I Changed The Fuel Pump...
Asked by
myyout
1999
CHEVROLET TAHOE
1999 Chevy Tahoe Fuel System Wiring
Engine Performance Problem 1999 Chevy Tahoe V8 Automatic Need Wiring Diagram For Fuel Pump, Relay And Ecu Wiring To Relay. Looking...
Asked by
cheech1
1 IMAGE
1999
CHEVROLET TAHOE
VIEW MORE
SPONSORED LINKS
Engine Oil Leak
Is Your Engine Cool Enough to Check?
Spark Plug Replacement Mercedes Benz C230
Online car repair manuals
