Check engine blinks about every one-half second it no longer pauses, just blinks until ignition is turned off?
MARK NABCLAW
  • 1993 TOYOTA PICKUP
  • 2.4L
  • 4 CYL
  • MANUAL
  • 250,000 MILES
Using OBD1, assume properly connected and rechecked and retested more than once giving the same result, which is: Check engine blinks about every 1/2 second. No longer pauses, just blinks until ignition is turned off. What does this type of result indicate?
Thanks,
Natch
Thursday, September 1st, 2022 AT 1:24 PM
  • 108,443 POSTS
A constant flashing when testing for codes indicates there are none stored. That is usually an indicator of a mechanical fault and not an electrical one.
What is the truck doing?
Also, here is a link that explains how to test for codes on this truck. Confirm this is what you are doing.
https://www.2carpros.com/articles/toyota-trouble-code-definitions-and-code-gathering-method-1990-1995
Thursday, September 1st, 2022 AT 8:41 PM
