No fire
FLOPPYBUTT
  • 1992 FORD RANGER
  • 2.3L
  • 4 CYL
  • MANUAL
  • 200,000 MILES
The truck will crank, but it will not start. I am not getting fire to the coil packs. I have replaced the ignition control module and the computer.
Monday, May 30th, 2016 AT 1:15 AM
HMAC300
  • 48,601 POSTS
Scan for codes first then check fuses in truck, also there are three different systems on this truck so it is helpful if you know what you have.
Monday, May 30th, 2016 AT 6:04 AM
FLOPPYBUTT
Thank you very much for your help. Yesterday I checked the ignition control module, the coil packs, and the crankshaft piston, using the tests on your site. They let me know it is the coil packs that are bad. I am ordering them today.
Thank you
Tuesday, May 31st, 2016 AT 1:17 PM
KEN L
  • MASTER CERTIFIED MECHANIC
  • 42,973 POSTS
Nice work let us know how it turns out.
Tuesday, May 31st, 2016 AT 6:23 PM
