No codes yet definite issue, the vehicle is having a hard time getting up to speed in order for the transmission to shift from gear to gear?
BASHWHEELS
  • 2001 SUBARU LEGACY
  • 2.1L
  • 6 CYL
  • MANUAL
  • 180,000 MILES
My vehicle listed above still runs but it does not want to. When driving there is no problem shifting into gears, but it clearly is having a hard time getting up to speed in order to shift from gear to gear. There are no codes on the dash. Also, there is some type of lubricant leaking from somewhere as it is dripping down to the exhaust causing smoke once the vehicle has been on for a few minutes. The car is not overheating. Checked oil for engine and transmission fluid. I expected one of them to be low as there is clearly fluid coming from somewhere. The dipsticks read appropriately. I have done a test for the head gasket by seeing if there is any air coming up and out of radiator with the cap off and car running for 5 minutes, there was none.
Thursday, March 14th, 2024 AT 3:56 PM
  • 108,328 POSTS
Does the check engine light stay on or flash while the engine is running? When you scanned for codes, did you scan the entire can-bus system?
What color is the fluid you see? Also, a faulty head gasket may not produce pressure in the cooling system. Do you notice any white smoke from the exhaust? Take a look through this link and let me know if anything mirrors what you are seeing:
https://www.2carpros.com/articles/recognizing-the-symptoms-understanding-a-blown-head-gasket-in-your-vehicle
Thursday, March 14th, 2024 AT 8:32 PM
