First read this tutorial on how to test the window switch and motor:
https://www.2carpros.com/how_to/power_window.htm
If you're not getting power to the switch, then check the fuse and wiring. If you get power and the switch works, then remove the motor from the regulator and push the switch in each direction (with the motor still connected to the switch). If the motor turns then you've got a stuck regulator, if the motor doesn't turn then the motor or connection to the motor is bad.
The switch is only $22
0.3 hours to replace but you could easily replace it yourself.
the motor is $300, plus an hour labor
the regulator is $66 with a 1/2 hr labor
SPONSORED LINKS
Tuesday, September 10th, 2019 AT 4:27 PM
(Merged)
