Air Bag Reset
JRAWLE
  • 1996 NISSAN SENTRA
  • 4 CYL
  • 109,500 MILES
Just bought this as a run around for $1500 knowing I would have to spend some money to make it roadworthy. It failed state inspection on a flashing air bag warning light. Nissan dealer says it will cost over $700 for the new sensor plus labor. I don't know what I get for $50 and I am not at all mechanical so I doubt that I could reset this thing myself. Should I play it safe and go with the dealer?
Friday, January 15th, 2010 AT 4:26 PM
2CARPRO JACK
  • 11,533 POSTS
You dont have to go to the dealer, but I would use a shop for this repair.Depending on the code in the system, it may not be the air bag itself, but a impact sensor or other item.regardless, when the repair is complete you will have to clear the computer (SRS System) with a scan tool, it wont reset by itself
This video will help tell what is wrong
https://youtu.be/gnSGfEqrf_w
Tuesday, January 19th, 2010 AT 8:00 AM
CHAOSMASTER1
  • 5 POSTS
First of all I hope I am not breaking any rules but this is a remedy to the situation if it does it again then there is a problem. Here it is I found it by googling it:
Open driver door
Get in
Shut door
Turn ignition to the on position The one that will go all the way, but not to start car)
Open door
Reach down with your right hand if your a rightty
Press the door ajar sensor button thing (7) times
Shut door
Start your car.
Takes practice to nail it right though. Any problems, just ask me.
Friday, March 5th, 2010 AT 11:47 PM
ISMA
CHAOSMASTER1 Thank you very much for providing the solution. I was successful with my 1996 Nissan Sentra. I'm happy :)
Monday, December 4th, 2017 AT 11:34 AM
  • 31,937 POSTS
Interesting remedy for that problem, I have not come across that fix before, if the check light comes back on, I would get a scan to see what the codes are, but for now, if the light is off it will be code free.
Monday, December 4th, 2017 AT 6:15 PM
