HOME
ASK A QUESTION
REPAIR GUIDES
BECOME A MEMBER
LOG IN
Login with Facebook
OR
Remember me
NOT A MEMBER?
FORGOT PASSWORD?
CONTACT US
PRIVACY POLICY
TERMS AND CONDITIONS
Home
Nissan
Sentra
Engine
Serpentine Belt
Replace/Remove
1994 Nissan Sentra belts
BIGVEE
MEMBER
1994 NISSAN SENTRA
4 CYL
FWD
MANUAL
100,000 MILES
What pulleys do you have to remove to change the timing belt and the water pump?
Wednesday, February 20th, 2008 AT 8:04 PM
BMRFIXIT
MECHANIC
You are doing timing belt or drive belts
engine size too?
SPONSORED LINKS
Wednesday, February 20th, 2008 AT 9:54 PM
Please
login
or
register
to post a reply.
Related Serpentine Belt Replace/Remove Content
Alternator Belt Change
Ive Loosened The Lock Nut And Adjusting Bolt And Still Can't Get The Pulley To Release The Old Belt. Is There A Pivot Point/bolt Or Am I...
Asked by
spankyno
4 IMAGES
1999
NISSAN SENTRA
GUIDE
Serpentine Belt Replacement
Need to change your serpentine belt? This is an easy job in most cases. There are several names used to describe a serpentine belt, including: drive belt, poly-v belt, multi...
2006 Nissan Sentra
2006 Nissan Sentra 44,500 Miles Around How Much Will It Cost To Replace A Drive Belt
Asked by
Renata Marshall
1 ANSWER
2006
NISSAN SENTRA
2002 Nissan Sentra Alternator Belt
How Do You Change Out An Alternator Belt On This Car?
Asked by
lssatter
1 ANSWER
2002
NISSAN SENTRA
How Do I Replace The Alternator Belt?
Asked by
spankyno
1 ANSWER
4 IMAGES
1999
NISSAN SENTRA
1999 Nissan Sentra Alternator Belt
How Do You Go About Changing An Alternator Belt On This Car?
Asked by
kevgoud
1 ANSWER
1999
NISSAN SENTRA
VIEW MORE
SPONSORED LINKS
Serpentine Belt Replacement Ford
Serpentine Belt Replacement Chevrolet
Serpentine Belt Replacement Acura MDX
Online car repair manuals
