Power window fuse location?
GMARRA
  • 2005 NISSAN ALTIMA
  • 99,000 MILES
My power windows and locks stopped working. None of the controls on any of the doors seem to work except for the side view mirror controls. The power locks do still work with the remote though. Also, not sure if it's related but at about the same time, the front driver side door stopped opening from the outside but still works from inside.
Which fuse controls the power windows and door locks? Or should they all be pulled and inspected? Nissan does not have any fuses on the Altima that are labeled "Windows" or "PW" and there is no fuse box diagram explaining what each fuse is for in the owner's manual.
By the way, the factory installed fuses are not transparent and you cannot see a blown fuse just by looking at it so you will need to replace and test to determine if the fuse is bad. And without knowing which fuse controls the power windows you will NOT be able to determine if you have tested the right fuse.
I have the same problem - no power windows or door locks (but power locks work with key fob so power is getting to the locking mechanism) and I am desperate for a real answer.
Sunday, August 25th, 2013 AT 3:48 PM
KEN L
  • MASTER CERTIFIED MECHANIC
  • 42,836 POSTS
I have found some door lock and window wiring diagrams for you so you can check the fuses and do some checking of the BCM which drives the systems. Please check fuse #1 and #6 in the interior fuse panel (left side of dash)
Fuse panel diagrams (below) Please run some tests and get back to us so we can continue helping you.
Monday, May 29th, 2017 AT 10:43 PM
THESTAV
  • 2003 NISSAN ALTIMA
  • 6 CYL
  • FWD
  • MANUAL
  • 104,000 MILES
I have a 2003 Nissan Altima 3.5L V6. The 12v outlet on my lower dash doesnt work. I cannot seem to find what fuse runs it. Ive looked in both fuse boxes but I just cant seem to find which one it is. I know this might not be the fix but it was in my old car. Any help on where it is or where I can find some info to find it?
Monday, April 8th, 2019 AT 5:16 PM (Merged)
  • 31,938 POSTS
Check fuse 5 with a test light, it will be the fuse next to the cig lighter fuse.
CANDLEQUEEN
  • NISSAN ALTIMA
1999 Nissan Altima, 125,000mi Can anyone tell me where I would locate the fuse box?
FISHERMAN
  • 938 POSTS
Hello !!
Here you have the location:
https://www.2carpros.com/forum/automotive_pictures/576_99_nissan_altima_fuse_panel_1_1.jpg
Good Luck!
POTATOCANYON
  • 2004 NISSAN ALTIMA
  • 4 CYL
  • FWD
  • 80,000 MILES
Where is the low beam fuse located?
Thursday, January 9th, 2020 AT 11:11 AM (Merged)
KEN L
  • 42,836 POSTS
Hey POTATOCANYON,
It looks like there are several fuses (9, 12 and 6) and two relays including the DRL module that controls the headlights.
Here is a guide and a diagram that will help you get the problem fixed.
and
Please run some test and get back to us.
Best, Ken
CARLOS N
  • 4 CYL
  • 189,000 MILES
Where is the fuse and relay box Fuse Relay Box?
BLUELIGHTNIN6
  • 16,542 POSTS
If the used one is good then yes you can, fuse boxes rarely fail so it should hopefully last several years.
ALBERTGSALINAS
  • 4 CYL
  • FWD
  • 150,600 MILES
Hi, my name is Albert. I have a quetions. My A/c just broke down, and would like to find out where, and what fuse n# would be to be replaced. My mechanic, found -out that my air compressor might be out. Also, my mechanic advised me to find out if any of the fuses are to be replaced, before trying to buy a refurbished unit. That is a refurbished A/C compressor to be exact.
Monday, January 13th, 2020 AT 10:45 AM (Merged)
  • 31,938 POSTS
Hi there,
These are all the fuses for the heater A/C system, i would also be checking that the refrigerant charge is not low as this is often the cause of no A/C as if there is a leak the low pressure switch will shut the system down.
Here is a guide with the fuse diagrams below.
STEPHANIEHILTON
  • 2006 NISSAN ALTIMA
  • 120,000 MILES
The lights inside won't come on. The dash and radio lights work but all the other lights don't. I think it might be a fuse but I don't have a fuse diagram to my car. It didn't have one when I bought it. So I need a picture or what fuses do I need to chenge. Thanks
Monday, January 13th, 2020 AT 10:46 AM (Merged)
  • 31,938 POSTS
It will be the globe or the switch in the light.
STEPHANIEHILTON
Do you know what fuse I would need to change for interior lights?
  • 31,938 POSTS
Power for this is directly from the body control unit, check power at the pink/black wire going into the dome light, if no power there check that there is power at the body control module pin #56 but if the step lams and spot lamps are working these share a common power supply.
STEPHANIEHILTON
Where do I find the body control unit at? Does anyone know any websites or where I can find a fusebox diagram photo or where I can find what fuses go to my dome lights and my trunk lights?
ANJALU27
  • 2002 NISSAN ALTIMA
Im looking for the shift lock fuse.
Im having this troubleshooting with my car, had chance the computer but car wont acelarate over 25 mph.
If someone can give any ideas. Will apreciate.
DRCRANKNWRENCH
  • 3,380 POSTS
There is a fuse box diagram on the back of the fuse box cover. We don't have fuse box diagrams in our service manual database for this reason.
ANJALU27
I already ckeck the cover, but dont have the diagram.
Either the owner manual or the book have this diagram.
Do you have aby idea what can be wrong with my car. It start but you can go over 25 mph
DRCRANKNWRENCH
  • 3,380 POSTS
First have the trouble codes pulled. Any Advance Auto or Auto Zone will do this for free.
You might want to check the fuel pressure if no codes come up. The same parts stores will loan you a fuel pressure test kit.
