My car will start, but it will not move. The cluster lights up and stays stuck in park, but the shifter moves.
Friday, June 10th, 2016 AT 12:29 PM
HMAC300
MECHANIC
Scan for codes It may be the switch on transmission that tells cluster what gear you are in. A scanner would be able to point that out, but not one from an auto parts. A transmission professional will need to conduct the scanning for you with a professional grade scanner.
