Engine swap?
LARRY NASON
  • 2005 DODGE MAGNUM
  • 5.3L
  • V6
  • 4WD
  • 90,000 MILES
I have a 5.3 all-wheel drive where the seats motor, I'm trying to do an engine swap on it I have right here a 5.3 rear wheel drive is there any difference other than the oil pan between the motors? Can I just swap my oil pan with this other oil pan and use this motor.
Sunday, May 14th, 2023 AT 3:44 PM
  • 108,554 POSTS
It should only be the pan that is different. Is the engine from the same year vehicle? If so, I know they didn't make any changes to the block. Also, I'm assuming you meant to say it is a 3.5L, correct?
Sunday, May 14th, 2023 AT 9:54 PM
