Engine fan not working?
NMONDO
  • 1996 MAZDA PROTEGE
  • 180,000 MILES
My fan inside my engine is not working, I noticed an engine problem when I saw white vapor from my hood when parking. Looking into the engine I saw antifreeze splattered over the pressure cap near the front of the engine. The reserve coolant was pretty much empty. I assume it boiled over for one reason or the other when the fan wasn’t working. Do you think the problem could be the thermostat? Fan Motor? Or fuses? I haven’t tested fuses because I don’t know how, would you be able to send me a diagram or video? Thank you.
Saturday, September 16th, 2023 AT 7:44 AM
  • 108,371 POSTS
The first thing to check would be the fuses. There are also relays and the radiator fan itself that can be checked, but let's do one thing at a time.
As far as the fuses are concerned, there are a few of them that can cause the issue. However, I need to know if you have a 1.5L or a 1.8L engine. They were both offered.
As far as checking a fuse, once we determine which to check (based on engine), here is a link that explains how it's done:
Also, when you turn the A/C on, one of the fans should also turn on. Check to see if that is happening.
Sunday, September 17th, 2023 AT 2:51 PM
