1999 Mitsubishi Galant SRS
DAVID4243
  • 1999 MITSUBISHI GALANT
  • 4 CYL
  • FWD
  • 120,000 MILES
The SRS light keeps popping up and I don't own a manual for this vehicle. I notice that the car engine seems to be shaking whenever I'm stationary like at a light or in a parking spot. The other day I turned the key in the ignition and at first the car didn't turn over. Then when I tried the second time it did.
What does the SRS light mean?
Thanks.
Sunday, February 1st, 2009 AT 12:30 PM
VDOG72
SRS means Supplemental Restraint System. It is the system that control your airbags.
The light coming on could be plenty of different reasons:
- Battery Low
- Blown Fuse
- Faulty Airbags
- Unplugged or faulty sensor
Best way to check would be with a scan tool.
As far as the car not turning over, the SRS has nothing to do with that.
I know there is a recall for 99 - 01 Galants for a faulty battery cable, might be worth it to check it out.
Let me know how it works out for you, best of luck!
- V
Tuesday, February 3rd, 2009 AT 10:02 AM
