Replaced instrument cluster with new/used with incorrect mileage, can it be corrected
VULCANO3179
MEMBER
1999 VOLKSWAGEN POLO
1.6L
2WD
MANUAL
57,106 MILES
I recently replaced my instrument cluster on my car listed above GL
model. Before I did this the mileage was 57,106, now that I have a different cluster it reads 63,347. Is it at all possible for a mechanic to correct the mileage?
Many thanks.
SPONSORED LINKS
Friday, August 16th, 2019 AT 4:48 AM
STEVE W.
MECHANIC
Welcome back. Yes it is possible for it to be corrected but you would need a dealer to do it as it requires a security code to adjust the mileage.
Friday, August 16th, 2019 AT 5:36 PM
VULCANO3179
MEMBER
Okay, so would it pass an mot with the wrong mileage? As my nearest VW dealer is 15 miles away.
SPONSORED LINKS
Friday, August 16th, 2019 AT 10:50 PM
STEVE W.
MECHANIC
Being in the US I'm not sure if it would be an issue. I know here it wouldn't be simply because the "new" number is higher than the old one. However if you go to
You can download the test sheet and the instructions as to what has to be checked to get an MOT completed in the UK if that is where you are located.
Friday, August 16th, 2019 AT 11:21 PM
VULCANO3179
MEMBER
Hi, yes I am in the UK. I will take your advice and do some research. Thank you for your help and time, many thanks.
Saturday, August 17th, 2019 AT 3:39 AM
STEVE W.
MECHANIC
That is the gov. Site for the MOT. It will not let anyone outside the UK download it because of the "security rules" they have in place. I asked a friend who does MOTs but have not heard back.
