Metal shavings found in the fuel pressure sensor?
GBREAUX1983
  • 2012 FORD F-350
  • 6.7L
  • V8
  • TURBO
  • 4WD
  • 210,000 MILES
Exactly what all do I need to change on my 6.7L turbo diesel since metal shavings were found in the fuel pressure sensor?
Saturday, July 29th, 2023 AT 2:55 PM
BORIS K
  • 771 POSTS
Your vehicle is fitted with the Bosch CP4 high pressure fuel pump which is common for internal failure. If you have metal shavings in the fuel pressure regulator you will have to start at the high-pressure pump, source of shavings, move on to the injectors, fuel pressure regulator, fuel pressure sensor, fuel rail, fuel filter housing and filter, fuel lines. The fuel tank will need to be removed and flushed, in tank fuel pump replaced.
Unfortunately, the metal shavings are circulated right throughout the fuel system and can be deposited virtually anywhere.
The complete system will need to be replaced for the shop doing the work for you to warrant the repair.
A good write up:
https://www.xtremediesel.com/blog/2021/09/01/what-is-a-cp4-pump-and-why-does-it-fail/
A bit of a longwinded video:
https://youtu.be/fdCWm_tNjb0
Cheers, Boris
Monday, July 31st, 2023 AT 8:00 AM
