HOME
ASK A QUESTION
REPAIR GUIDES
BECOME A MEMBER
LOG IN
Login with Facebook
OR
Remember me
NOT A MEMBER?
FORGOT PASSWORD?
CONTACT US
PRIVACY POLICY
TERMS AND CONDITIONS
Home
Mercury
Villager
Ignition
Plug Wire
SPONSORED LINKS
Spark Plug Wire
CHARLESCAS
MEMBER
MERCURY VILLAGER
Hello Sir
I have a 1993 Mercury Villager. I accidentally took off all the spark plug wire and now I don't know the order could you please help me.
Wednesday, June 14th, 2006 AT 2:11 PM
EPERRY
MECHANIC
You could go to the ford and the will print you a copy or buy the book on your make of car witch got the firing order in it.
SPONSORED LINKS
Friday, July 21st, 2006 AT 4:42 AM
DYABALLIKL
MEMBER
Not sure about villagers. If it's the same as in the aerostar (which, in all likelihood, it is).
Wednesday, July 26th, 2006 AT 12:51 AM
Please
login
or
register
to post a reply.
Related Plug Wire Content
1999 Mercury Villager No Spark!
Engine Mechanical Problem 1999 Mercury Villager 6 Cyl Front Wheel Drive Automatic My Car Failed The Emissions Test Due To The Knock...
Asked by
robertcgs
1999
MERCURY VILLAGER
2000 Mercury Villager No Spark To Plugs
Changed Plugs, Wires And Distributor Cap And Rotor No Spark To Ay Plug ? Fuse Or Need Complete Distributor Replacement, Took Regulator...
Asked by
chris hazelwood
1 ANSWER
2000
MERCURY VILLAGER
Distributor
Distributor Details Or Anything That Will Help Us Figure Out Why The Gears Are Not Turning At All Without No Fire Getting To The Distributor...
Asked by
angeleyes19940
1 ANSWER
2002
MERCURY VILLAGER
1993 Mercury Villager Distributor
I Think The Distributor Is Gone, What Is Involved In Replacing This?Is It Something For The Home Mechanic Or Should I Take It To A Shop?...
Asked by
hippy-60
1 ANSWER
1993
MERCURY VILLAGER
1993 Mercury Villager How Do You Check The Timing On...
Hello I'm Not A Proffessional In Mechanic But I Wanna Try To Change The Timing Belt But I Don't Know How To Check The Timing, Could You...
Asked by
Oscarcanchola
1 ANSWER
1993
MERCURY VILLAGER
VIEW MORE
SPONSORED LINKS
Intermittent Misfire
Misfire
How to Repair an Engine Cylinder Misfire
Online car repair manuals
