HOME
ASK A QUESTION
REPAIR GUIDES
BECOME A MEMBER
LOG IN
Login with Facebook
OR
Remember me
NOT A MEMBER?
FORGOT PASSWORD?
CONTACT US
PRIVACY POLICY
TERMS AND CONDITIONS
Home
Mercury
Villager
Engine
Symptoms
Not Running
SPONSORED LINKS
1994 Mercury Villager Won't Start
RPRZYBYLO
MEMBER
1994 MERCURY VILLAGER
6 CYL
FWD
AUTOMATIC
128,000 MILES
The vehicle cranks over but will not start has fuel pressure. Starts when starting fluid is sprayed but stalls after.
Monday, November 2nd, 2009 AT 10:44 AM
MECHANIC
Check the fuel pressure to rule the fuel pump and also check for injection pulses from the injector/s
SPONSORED LINKS
Monday, November 2nd, 2009 AT 11:17 AM
RPRZYBYLO
MEMBER
The injector has no pulse but how would I fix that?
Monday, November 2nd, 2009 AT 11:25 AM
MECHANIC
Check for power on the injector harness and if its there and still no pulse test the injector and also the computer's ground driver/s
Monday, November 2nd, 2009 AT 11:28 AM
Please
login
or
register
to post a reply.
Related Engine Not Running Content
1994 Mercury Villager It Wont Start. It Wont Turn Over, Or Take A Jump, But There Is Enuf Juice To Run The Radio And Windows. The...
Asked by
dajjrus
1 ANSWER
1994
MERCURY VILLAGER
VIDEO
How to fix an engine that wont start
Instructional repair video
GUIDE
Engine Not Starting - Top 3 Easy Steps
Over the past 20 years on 2CarPros we have identified the top three problems that are easily fixed. This can save you a trip to the repair garage or calling a tow truck and...
1995 Mercury Villager Why Won't It Start?
Engine Performance Problem 1995 Mercury Villager 6 Cyl Automatic My Villager Will Start And Run For A Couple Of Hours But Then It...
Asked by
michaelreinier
1 ANSWER
1995
MERCURY VILLAGER
Will Not Start After Re-timed
I Have Put The Crank Back To Time Mark The Cams Back To Time Mark I Even Put The Distributor On On Number One Plug And The Van Will Not...
Asked by
mrvanover
1993
MERCURY VILLAGER
2000 Mercury Villager Won T Start
Electrical Problem 2000 Mercury Villager 6 Cyl Front Wheel Drive Automatic I Have Changed The Battery Changed The Altanator Made Sure...
Asked by
Eng14ine
1 ANSWER
2000
MERCURY VILLAGER
Won't Start Has Gas, Spark
Changed The Knock Sensor, Now It Won't Start Just Cranks. Distributor Brand New There's Sparks On All Plugs. Checked Gas Flow From Filter...
Asked by
Tom steal
1999
MERCURY VILLAGER
VIEW MORE
SPONSORED LINKS
Not Running - Advanced
Crankshaft Sensor Replacement
Online car repair manuals
