Turn signal flasher
MICHAEL MCINTIRE
  • 1998 MERCURY SABLE
Electrical problem 6 cyl Front Wheel Drive Automatic 140000 miles
I've read through my so called owners manual for this car and cannot find the turn signal flasher location. Where is it located on the '98 Sable?
Friday, September 12th, 2008 AT 8:47 PM
KEN L
  • MASTER CERTIFIED MECHANIC
  • 47,256 POSTS
The turn signal flasher is located on the driver's side under dash by the footwell.
Here are the instructions and location of the flasher unit so you can change it out. (Below)
Cheers, Ken
Saturday, November 11th, 2017 AT 7:49 PM
JCORDY
Electrical problem
1998 Mercury Sable Two Wheel Drive
My signals work only when the 4 way flasher is pushed in, the four way flasher when out doesnt work, fuses look good, is there any thing else I can look at to see if it is the problem before I rip the steering column apart.
Wednesday, October 7th, 2020 AT 12:16 PM (Merged)
BLUELIGHTNIN6
  • 16,542 POSTS
Inspect your flasher before going into the steering column..It is located under the left side of dash, pictured below..
https://www.2carpros.com/forum/automotive_pictures/261618_Noname_238.jpg
Thanks for using 2CarPros.com!
WILLSMITH
  • 1995 MERCURY SABLE
Electrical problem
1995 Mercury Sable 6 cyl Wheel Drive Type unknown Automatic 100000 miles
where is the flasher unit located? This for turn signals.
The electronic flasher is located at no.11 see below
https://www.2carpros.com/forum/automotive_pictures/12900_flasher_3.jpg
BABYGURL5821
Electrical problem
1995 Mercury Sable 6 cyl Front Wheel Drive Automatic
I need the location of the flasher on a 1995 Mercury Sable
2CARPRO JACK
  • 11,533 POSTS
It is behind the left side of the dash, above fuse block
BABYGURL5821
Can you tell me or show me what it looks like?
2CARPRO JACK
  • 11,533 POSTS
I cant seem to find a good picture of it. Try going to the parts house and looking at a new one, then you will know what it looks like.
SMITHD7
  • 1993 MERCURY SABLE
  • 6 CYL
  • 115,000 MILES
The turn signals will not work, hazard flashers work fine. Could you tell me where the flasher is located for the turn signals, and what it might look like?Also if this is not the problem, just what I might look for.
If the stalk is bad how do I tell?
Thanks so much
BMRFIXIT
  • 19,053 POSTS
Flasher relay would be 1st to replace its located
Behind left side of dash, above fuse block
good luck
https://www.2carpros.com/forum/automotive_pictures/99387_Untitled_11.jpg
