Fuel pump shut-off switch location
TONY1008
  • 2001 MERCURY COUGAR
  • 2.5L
  • 6 CYL
  • FWD
  • 160,000 MILES
How do I reset or turn back on the fuel pump shut-off switch?
Monday, February 2nd, 2015 AT 11:04 AM
KEN L
  • MASTER CERTIFIED MECHANIC
  • 42,840 POSTS
That switch is known as the inertia switch and triggers if you hit a large bump or if the car is jarred. It is located under the drivers or passengers side near the kick panel. Here is a diagram (below). Check the bottom on top it will be up if the sensor has been triggered. Push it down to reset it.
Cheers, Ken
Wednesday, June 21st, 2017 AT 9:00 PM
JBAR13
  • 6 CYL
  • FWD
  • 145,000 MILES
Can someone post an image and a guide to find the inertia switch? Because I think I found where it is so I can change my fuel filter. I do not want to activate the wrong thing thinking it is something else.
Tuesday, September 25th, 2018 AT 11:29 AM (Merged)
MERLIN2021
  • 17,250 POSTS
The inertia switch is behind the driver side kick panel. Here is a diagrams below that show the location.
Cheers
Tuesday, September 25th, 2018 AT 11:30 AM (Merged)
JIMESTYLE
  • 150,000 MILES
Please help me get my car running, as I cannot find a Chilton or Haynes manual for my car. I have a new fuel pump, but need to know where the fuel pump relay and inertia switch are located? The resources I have found on line are generic at best, and totally useless at worst. Thank you!
SATURNTECH9
  • 30,870 POSTS
The fuel pump relay is in the left front corner of engine compartment in battery junction box. The inertia switch is behind the left kick panel.
WRENCHTECH
  • 20,757 POSTS
The Inertia switch is behind the passenger side kick panel.
Here is the fuel pump relay:
https://www.2carpros.com/images/external/86441631.gif
WRENCHTECH
  • 20,757 POSTS
Sorry Louie, we posted at the same time. Your answer is correct on the Inertia switch. It is on the driver's side, not the passenger.
SATURNTECH9
  • 30,870 POSTS
I was going to thank you for correcting where the inertia switch was before you told me I was right, lol. I know the Ranger trucks are on the passenger side.
