1987 Other Mercedes Benz Models White Smoke From the exhaust
RSXVSCELL
  • 1987 MERCEDES BENZ
Engine Mechanical problem
1987 Other Mercedes Benz Models 6 cyl Two Wheel Drive Automatic
hello, my name is alex, and I have mercedes 300e 1987 fuel not Sd, and I am facing a problem that my car is smoking white smoke from the exhaust when my rpm nearly fully loaded in it's ground not while moving, is this mean that I have a problem with my motor please help me with my problem, knowing that I want to know if the kind of oil affect in this problem, please help me.
2. And knowing that my rpm while the car is not moving at ( idle ), sometime 8, and sometime 12, and the mechanic solve the problem and after the heat of a motor the problem pre-exist and thank you.
Sunday, September 14th, 2008 AT 4:46 PM
  • 31,937 POSTS
Hi there,
if your car is not using coolant and not over heating I would be checking the transmission vacuum modulator, as it may have a pin hole in it and drawing transmission oil into the engine, this will cause white smoke.
Mark (mhpautos)
Sunday, September 14th, 2008 AT 6:40 PM
RSXVSCELL
Hello again and thank you for your answer, but knowing that the white smoke is only when the car is idle not moving, when the car is fully speed loaded in ground not movie this white smoke comes from the exhaust, and I also please want to know if this problem occur when I put a regular oil and a synthetic oil type because now I have in my car 2 types of motor oil, and please I want to know what is the best oil type I can use for this car and thank you
Monday, September 15th, 2008 AT 1:43 PM
  • 31,937 POSTS
Hi there, engine oil will burn with a dark blue smoke, coolant, transmission oil and brake fluid will burn with a very white smoke, so get your mechanic to check this out.
Mark (mhpautos)
Monday, September 15th, 2008 AT 5:29 PM
