HOME
ASK A QUESTION
REPAIR GUIDES
BECOME A MEMBER
LOG IN
Login with Facebook
OR
Remember me
NOT A MEMBER?
FORGOT PASSWORD?
CONTACT US
PRIVACY POLICY
TERMS AND CONDITIONS
Home
Mazda
Other
Ignition
Distributor
Pick Up Coil
SPONSORED LINKS
Pick up coil
CGERTKEN
MEMBER
MAZDA
Is the ignition coil and a pick up coil the same thing
Wednesday, February 8th, 2006 AT 1:22 PM
2CARPRO JACK
MECHANIC
No one is the actual firing coil and the other is used as a cam or crank angle sensor
SPONSORED LINKS
Wednesday, February 8th, 2006 AT 3:25 PM
CGERTKEN
MEMBER
Where can I find a picture of each?
Wednesday, February 8th, 2006 AT 3:39 PM
Please
login
or
register
to post a reply.
Related Ignition Distributor Pick Up Coil Content
1995 Mazda Mazda Familia 1995
Shakes Or Wobbles Problem 1995 Other Mazda Models Two Wheel Drive Automatic 175000 Miles I Have This Problems: 1--- Car Was Going Fine...
Asked by
rumaoaparna
1 ANSWER
1995
MAZDA OTHER
What Can I Do To Fix My 1998 Mazda After I Put In A...
The Car Wants To Start But It Cant't Start I Have Tested Ity And Put A New Coil In Yesterday.
Asked by
Abel.Mendoza81
1998
MAZDA OTHER
1996 Mazda No Spark
It A 96 Maxda Mx6 2.0l Auto Trans I Replaced The Engine And Also Got The Head Resurficed It Has Good Compression It Has Fuel But No Spark I...
Asked by
Jett
1996
MAZDA OTHER
1996 Mazda Spark Plug
When I Purchased My Mx6 I Was Told It Has A Cracked Head Or Maybe Blown Head Gasket. My Boyfriend Put Liquid Glass In It And It Seemed To...
Asked by
wwa
1 ANSWER
1996
MAZDA OTHER
1988 Mazda 2200 Longbed Has No Spark (84000 Miles)
I Tested With A Screwdriver From The Sp Wire To Ground And The Coil Wire To Ground - No Spark. The Engine Turns Over Rapidly Nut Does Not...
Asked by
Ed_123
1 ANSWER
1988
MAZDA OTHER
VIEW MORE
SPONSORED LINKS
Spark Plug Replacement - Toyota Prius
Not Running - Advanced
How to Read Codes
Online car repair manuals
