HOME
ASK A QUESTION
REPAIR GUIDES
BECOME A MEMBER
LOG IN
Login with Facebook
OR
Remember me
NOT A MEMBER?
FORGOT PASSWORD?
CONTACT US
PRIVACY POLICY
TERMS AND CONDITIONS
Home
Mazda
MPV
Ignition
Firing Order
SPONSORED LINKS
Firing order
JOANNA.646
MEMBER
2000 MAZDA MPV
May I have the firing order or firing order diagram for a V6?
Friday, February 4th, 2011 AT 7:19 AM
MECHANIC
There are three engines that go in these are all all engine firing orders for you.
Firing order: V6 - 1-4-2-5-3-6 V6: - 1-2-3-4-5-6 Four cylinder: 1-3-4-2
Cheers
Images (Click to make bigger)
SPONSORED LINKS
Friday, February 4th, 2011 AT 8:59 AM
MARIONUNEZ
MEMBER
2000 MAZDA MPV
6 CYL
FWD
AUTOMATIC
150,000 MILES
What is the engine firing order and timing?
Tuesday, July 17th, 2018 AT 2:56 PM (Merged)
BLUELIGHTNIN6
MECHANIC
STEWARD1957
MEMBER
1 POST
1998 MAZDA MPV
Six cylinder two wheel drive manual.
I would like the firing order and the pison numbering as well if anyone knows of a repair manual to download.
MECHANIC
SPONSORED LINKS
JAMES MICHAEL CONWAY
MEMBER
1990 MAZDA MPV
2.5L
V6
2WD
150 MILES
Trying to get the timing right.
HMAC300
MECHANIC
Timing for a 3.0L V6 is 11 degrees btdc for auto/manual. Firing order is in picture. See picture.
Image (Click to make bigger)
2CP-ARCHIVES
MEMBER
2001 MAZDA MPV
150,000 MILES
Spark plug wire to coil diagram for 2001 mazda mpv needed. Thanks
Wednesday, October 3rd, 2018 AT 7:55 PM (Merged)
KHLOW2008
MECHANIC
Here is the engine spark plug firing order. Check out the diagrams (Below). Please let us know if you need anything else to get the problem fixed.
Please
login
or
register
to post a reply.
Related Firing Order Content
Lean Code On Bank 2, Dont Know Where Bank 2 Is...
I Have Had The Rear Three Plugs And Coils Replaced That Required The Manifold To Be Removed. I Replaced The Front Three Plugs Today And...
Asked by
ccaudill
2004
MAZDA MPV
Mazda Mpv
2000 Mazda Mpv V6 Timing Diagram
Asked by
joanna.646
1 IMAGE
2000
MAZDA MPV
1998 Mazda Mpv No Spark
Replaced Broken Timing Belt Put In Bran New Distribiter New Fuel Pump But I Have No Spark At All
Asked by
mark49
1 ANSWER
1998
MAZDA MPV
2005 Mazda Mpv
Engine Performance Problem 2005 Mazda Mpv Front Wheel Drive Automatic 67000 Miles My Car Has Been Jerking Alot And Not Having Alot Of...
Asked by
dhickman
1 ANSWER
2005
MAZDA MPV
Cold Start
In The Morning Or When It Sits A Long Time It Will Not Go. It Is Like It Falls On Its Face As Soon As You Touch The Gas, But If You Barely...
Asked by
George Yurjevich
1 ANSWER
2003
MAZDA MPV
VIEW MORE
SPONSORED LINKS
Misfire Random Code P0300
Spark Plug Replacement Ford Escape V6 3.0L
Spark Plug & Wire Replacement Chevy Avalanche
Online car repair manuals
