1996 Mazda Millenia
LARRY1951
  • 1996 MAZDA MILLENIA
  • 6 CYL
  • 146,000 MILES
The car starts up. After 10-15 minutes of running ithe engine stops running. It seems to me that some sensor or something gets hot and the engine gives out. I have had a distributor, water pump, timing chain recently installed. Can you help me. Thanks.
Sunday, October 17th, 2010 AT 6:19 AM
KHLOW2008
  • 41,814 POSTS
Hi larry1951,
Thank you for the donation.
After the engine stalls, were you able to restart?
Does opening the throttle keep the engine running?
Is the MIL showing?
Sunday, October 17th, 2010 AT 9:25 AM
LARRY1951
The car does restart after it stalls.
Nothing seems to keep the engine running for long after it stalls.
Nothing is showing
Sunday, October 24th, 2010 AT 7:43 AM
KHLOW2008
  • 41,814 POSTS
Get a scan done to check for trouble codes.
After it stopped running, were you able to restart?
Was it easy?
Did you test what was missing then?
Click the " First Things To Check " link at bottom of post to get an idea what to look for.
Sunday, October 24th, 2010 AT 8:21 AM
