1995 Continental Ride Control
JBARHITE
  • 1995 LINCOLN CONTINENTAL
When the air temp. Is about 50 Degrees or lower the CHECK RIDE CONTROL warning comes on. I reset the warning and it stays off until the car sits for an extended period of time in the cold. The compressor doesn't seem to run more then normal and the system seems to be OK. Thanks.
Sunday, November 18th, 2007 AT 2:22 PM
BMRFIXIT
  • 19,053 POSTS
Check for code s that will help pin the trouble area
and also u are looking for C code air suspension system
and not the P code
good luck
Sunday, November 18th, 2007 AT 3:27 PM
KEN L
  • MASTER CERTIFIED MECHANIC
  • 43,081 POSTS
Is the car sagging in the rear in after sitting for a while. If so, we have hade problems with the air pump in those cars. If the pump pulls to much amps for a extended amount of time the system will shut off and light the warning bulb. Replace the pump with new, also check the rear air bags for seepage and replace as needed.
Friday, November 23rd, 2007 AT 10:42 AM
