I just replace my radiator and my vehicle is still leaking and ever time I drive it it goes slow and it seems like it wants to stop.
Friday, June 3rd, 2016 AT 5:31 AM
HMAC300
MECHANIC
Have the coolant system pressure checked for an internal leak like a head gasket.
SPONSORED LINKS
Friday, June 3rd, 2016 AT 5:34 AM
NIKKIR
MEMBER
Would my vehicle leak coolant if the radiator fan is not spinning?
Friday, June 3rd, 2016 AT 5:49 AM
HMAC300
MECHANIC
Only if the fan does not work at idle and when the air conditioner is on while driving, it does not matter to much. It would not leak coolant anyhow it would blow it out the reservoir and your engine gauge would say hot or towards that, but have it pressure checked anyhow.
Friday, June 3rd, 2016 AT 7:11 AM
NIKKIR
MEMBER
If my water pump or my thermostat need to be change would it leak coolant?
Friday, June 3rd, 2016 AT 7:33 AM
HMAC300
MECHANIC
Pressure check this as I think you have a head gasket going out or have a professional look at it. If it was the thermostat it would over heat almost immediately, but there would be no power loss.
